BryanChung Posted April 5, 2005 Share Posted April 5, 2005 Hi. Everytime time when I power on my computer ... it will fail to even load into POST ... only the HDD LED keeps blinking and the monitor LED keeps blinking. Making me have to power off and on again. Then my POST will show the following just before continuing the normal process "DRAM timing is too tightly so reload timing" "Press any key to continue" Once press a key, Windows load. I don't remember touching anything ... so what is wrong with this actually? Link to comment https://www.neowin.net/forum/topic/305073-dram-problem/ Share on other sites More sharing options...
dreamz Veteran Posted April 5, 2005 Veteran Share Posted April 5, 2005 try relaxing your timings. did you accidentally set them? Link to comment https://www.neowin.net/forum/topic/305073-dram-problem/#findComment-585727572 Share on other sites More sharing options...
BryanChung Posted April 5, 2005 Author Share Posted April 5, 2005 how to relax the timing? i don't even know where. Link to comment https://www.neowin.net/forum/topic/305073-dram-problem/#findComment-585727671 Share on other sites More sharing options...
dreamz Veteran Posted April 5, 2005 Veteran Share Posted April 5, 2005 go into the bios and navigate to the memory section. what are your timings and what's your ram? can you reset your bios (either do it in the bios or take out the cmos battery for a little while)? Link to comment https://www.neowin.net/forum/topic/305073-dram-problem/#findComment-585727700 Share on other sites More sharing options...
BryanChung Posted April 5, 2005 Author Share Posted April 5, 2005 Can I find that out from here and post a screenshot for you? I have CPU-z Link to comment https://www.neowin.net/forum/topic/305073-dram-problem/#findComment-585727789 Share on other sites More sharing options...
BryanChung Posted April 5, 2005 Author Share Posted April 5, 2005 Anyone :no: Link to comment https://www.neowin.net/forum/topic/305073-dram-problem/#findComment-585728994 Share on other sites More sharing options...
